battery contact cable adhesive
I am rebuilding, having replaced the battery. In one of the later steps you heat the adhesive on the battery contact cable before gently removing. in the reverse - what adhesive should i use to fix the cable? it looks like its fixing to an aluminium patch - should i use thermal compound or regular hot glue or double sided tape?
thanks in advance
do you mean the flex cable from the battery with the gold contacts ?
由 daniel 完成的
yes that is it... It looks like it had a copper like adhesive or possibly tape of some kind.
由 SteveG 完成的
