跳转到主内容
加入维修社区 - 创建账户
Grand Prix 在 2004 年进行了更新,采用了 GM W 平台的改进版本,并于 2002 年 2 月 7 日在芝加哥国际车展上作为 Grand Prix G-Force Concept 概念车首次亮相。
cranks but fuel pump isn't coming
2005 grand prix clicking in dash cranks but fuel pump isn't coming on3800 series 3
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@pamelawilli3405 what have you checked? Sounds like either a bad relay or a bad pump. Do you hear the clicking continuously?
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
Any high mileage vehicle may have age related issues like a worn out fuel pump. If there's a fuel test valve on the fuel rail, capped with a black plastic cap, you may be able to manually test for fuel pressure. Remove the cap to reveal a Schrader valve, the same as tire valves. Turn on ignition without starting and try listening for faint sounds of the in-tank fuel pump humming/hissing in a quiet area. In theory, fuel pumps should run for a few seconds then shut off if the engine isn't started (safety). With a rag loosely covering the fuel test valve, depress the valve stem and see if fuel shoots out. Some find fuel shooting out over the engine but hence using a rag. A better test is borrowing a fuel pressure gauge from AutoZone or other auto parts store loaning out tools (free with either a credit card copy or cash), connect it to the test valve and have someone try starting as you observe the pressure gauge. Expect at least 30 psi. If this vehicle has over 100k miles, was the fuel filter replaced? Low or non existent fuel pressure may be; a blown fuel pump fuse, corroded wiring to pump, corroded pump ground connection, worn out or dead pump. A fuel test can help diagnose a fuel issue.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Pamela Williams 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 13
过去 30 天: 32
总计 813
