跳转到主内容
任天堂于2019年9月20日发布了在Switch系列中更加实惠、且更纯粹的掌上游戏机——Nintendo Switch Lite,它有着一体式的手柄设计以及更小的屏幕。
20 个问题 查看全部
How do I fix my switch lite blue screen?
I’ve checked putting pressure on the CPU but it didn’t seem to work and now i don’t know what to do. It belonged to my little brother and he seemed to have dropped it because after I opened it 2 of the tiny screw parts broke off. I’m pretty sure something in the CPU is damaged but I need help figuring out what and how to fix it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
My Nintendo Lite will not reset it has the blue screen of death anyway how to reset it?
完成的
添加一条评论
1个答案
最有帮助的答案
it can be cpu, nand or memory ic. this isn't a repair just anyone can do, if the cpu is at fault then it would need removed using a hot air station, cleaned and reballed. you would also need to check if any solder pads under the cpu are damaged and if some are then they would need repaired with micro jumper wires
这个答案有帮助吗?
得分 2
4条评论:
how do i fix my blue screen when my switch doesn't work
完成的
@taelynclayton it requires microsoldering repair
完成的
I need a repair I think because I can’t find out how to fix my Nintendo lite
完成的
@kaemengros has it got a blue screen ?
完成的
添加一条评论
添加你的答案
Ech0 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 442
