跳转到主内容
ROG Ally的维修和拆卸信息,这是华硕制造的一款手持游戏机。于2023年发布,型号为RC71L。
Screw list for ROG Ally
Hi guys, I'm looking for the list of screw using in the ROG Ally, specifically the middle short screw on the back panel. I unfortunately stripped it while replacing the SSD and looking to see where i can get a spare one
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
Have you been able to figure out the length?
完成的
添加一条评论
2个答案
The thread is M2, and the 5 long ones are M2 x 16, unfortunately, I don't know what the middle one is. I haven't had to replace that one. But it is an M2, just not sure what the length is, but if you can measure the length of the threads in mm (millimeters) than you have that number. Ex. M2x16 is thread pitch M2 x 16mm... Hope that helps.
这个答案有帮助吗?
得分 0
2条评论:
My three bottom screws can’t screw in. I don’t know what it’s called, but the gold things in the holes where the screw goes in came out.
完成的
I have the jsaux backplate. The gold things have come out of the front plate.
完成的
添加一条评论
The screw sizes for the exterior shell are m2 x 16mm for the 5 screws around the edges and it's m2 x 10mm for the middle bottom screw. I stripped my center one, so I took some measurements to figure out what size it was
这个答案有帮助吗?
得分 0
1条评论:
Does anyone know the screw type for the joystick screws?
I lost one mid replacement of drifting joystick
完成的
添加一条评论
添加你的答案
Bui Dave 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 36
过去 30 天: 127
总计 4,480
