跳转到主内容
Samsung's flagship tablet, released in March 2017. Identified by model number SM-T820.
32 个问题 查看全部
Does replacing the Charging Port Assembly require any SOLDERING
@dadibrokeit
Hi again Jerry :
Another question for you or anyone. Does replacing the above mentioned Charging Port Assembly ( Galaxy Tab S3 9.7 SM-T820) require any SOLDERING to replace?
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Barbara,
Assuming you're talking about the complete charging port assembly - the same one that's advertised here on iFixit - then no, you do not need to do any soldering to replace it.
After going through the Daughterboard Replacement guide, here are the tools you need.
  • Heat source: heating pad / iOpener / heat gun / blow dryer
  • Opening pick(s) / plastic card
  • Suction cup
  • Phillips #000 screwdriver
  • Spudger
Samsung Galaxy Tab S3 Daughterboard Replacement - iFixit Repair Guide
It appears that iFixit is out of stock on those daughterboards, but you shouldn't have any trouble finding a replacement on places like Amazon, eBay or AliExpress. Here's an example.
Charging Port Board For Samsung Galaxy Tab S3 9.7 SM-T820 / T823 / T825 / T827
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Barbara J Maggiani 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 58
