跳转到主内容
How to remove a Forgotten Firmware Password
Hi there, I recently received a macbook air from a friend who didn’t want it anymore, there seems to be a firmware password on it that I don’t know, nor does he know it, I do have root and admin access on the macbook. How can I reset the password? All help would be appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Check out this video. In order to reset the firmware password you would need to replace or reprogram the BIOS chip. This is a somewhat advanced procedure which requires special tools / skills. Good luck!
这个答案有帮助吗?
得分 2
3条评论:
@zpl is there any other way to do this process or is this the only method, I apologize for the late response.
完成的
There are some tools you can use to interface with the board directly to reprogram the EFI chip, but they can be pretty hacky, so use caution! There isn't an easier way to remove a firmware password without the password.
完成的
@zpl ok, thanks, are there any that you recommend?
完成的
添加一条评论
添加你的答案
TechVid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 350
