跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
Wont turn on at all
Hello i have a 16gb 3gs iphone it worked fine and than i didnt use it for a few months and now when i go to use it it wont cut on or charge or anything no sign of any type of charging when is plugged in either does have the red water dmg sticker but it worked completely fine and have had that for a long time i was wondering what might be the issue or any ideas on fixing this.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
My two guesses are dead battery (possibly finished off by being off for several months) or fried "other component" due to water damage. While the water may not have caused an immediate short, the water may have caused corrosion which built up in the time the phone was inactive. My suggestion would be to open the phone and due a visual inspection to see if anything is noticeably damaged. If all looks ok, try replacing the battery first. Let us know what you find.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
charlie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 820
