跳转到主内容
加入维修社区 - 创建账户
Released in 2014, Dyson's AM09 is a bladeless fan-heater combo. It comes with a remote for easy control.
Fan won't turn on (main fuse blown)
Hi, my Dyson AM09 fan was knocked over and stopped working. I've taken it apart and noticed the main fuse (F1) doesn't have continuity running through it. The rest of the circuit board looks fine (see images attached). However, I'm relatively inexperienced when it comes to electronics. If I replace the fuse, is there any way to ensure it doesn't instantly blow again?
I'm also struggling to locate the fuse (46211600000) in the UK. Would any T1.6A 250v fuse be a suitable replacement/ are there any specialist shop in London where I could locate a replacement part?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Does anyone know for sure the location of the infra red sensor on these?
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @aaronmason94673
You can order the fuse from Digikey UK
Without a schematic you could try is to use an Ohmmeter and with the power disconnected, measure between the output side of the fuse and an earth point on the board. You should not measure a short circuit i.e. 0.00 Ohms. If you do the fuse will blow.
Perhaps order 2 fuses that way if it does blow you have a replacement for after you find out why the 1st one blew. ;-)
这个答案有帮助吗?
得分 3
8条评论:
Hi @jayeff, thanks for this. I measured between the output side of the fuse and the earth point on the board and it didn't read a short so fingers crossed.
Unfortunately Digikey UK is coming from the US with some fairly expensive shipping costs. I found this on eBay which looks comparable (https://www.ebay.co.uk/itm/283199315985 -T1.6A) and comes in a pack of three, just in case, do you think it would work? Many thanks
完成的
Hi @aaronmason94673
Electrically i.e. rating wise they're OK but I think that the fuses you found would be physically too small to sufficiently bridge between the solder pads for the fuse on the motherboard for a good connection.
The fuses that you found are smd package size 2410 i.e. 6.1mm x 2.6 mm x 2.6mm. Scroll down to the bottom of the Ebay page that you linked.
I'm not sure but looking at the data sheet for the fuse series (462) you posted its size is 10.5mm x 4.5mm x 4.5 mm.
You can confirm this by measuring the dimensions of the faulty fuse that is in situ to get a rough idea of the actual size.
If you find a fuse that fits etc, don't be surprised if it blows too. Perhaps not when power is first connected and the fan is turned on but maybe when some other function is then selected e.g. hi heat etc.
There's always a reason why a fuse blows. Rarely does it fail of its own accord.
完成的
My HP01 has exactly the same issue after running it on an inverter. I got a 10pk of fuse from ebay and solder one on. Now the fan is working.
https://www.ebay.com/itm/392912111332?mk...
完成的
@billchishunho I have an HP01 that also appears to have the F1 fuse blown and I am going to be attempting the repair with the link in your comment. Have you experienced any issues since replacing the fuse? Do you have any tips for soldering on the new one?
完成的
I just used the fan last night again. It works great. I just laid the new fuse side way and bended the pins to be in contact with the end caps of the old fuse for soldering. I need to use solder wax to make the solder joints.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Aaron Mason 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 39
过去 30 天: 161
总计 4,983
