跳转到主内容
型号:A1419/ 2012/2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 专业版
330 个问题 查看全部
Chunklist validation failed from open core, any thoughts?
Trying to create Ventura installer from open core legacy patch 0.67 on my iMac 27” 2012 model, but always got this error, see attached screenshot, any one knows resolution to get through this?
Thanks,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
You need to get 0.8.8 release OpenCore
这个答案有帮助吗?
得分 0
6条评论:
@danj -- Hello Dan, thanks for your comments. However, after entering that site, unlike those old version like 0.6.7 or earlier, I didn't find any link for downloading the open core program which can create USB installer for Ventura OS, did I do anything wrong here?
Thanks,
完成的
@danj - That’s the patch I used which caused the error message. By the way, should I run this patch and create the usb installer on the machine which can run Ventura only (after 2017 models) or any old machine which needs to do this upgrade through open core?
完成的
@hru1207 - Not sure I follow you here. OpenCore gets bug fixes as well as enhancements which is why it’s updated.
As to which system can leverage OpenCore people are using in on much older systems to use the newer macOS versions.
I’m not an expert on OpenCore I’m currently using it on my 2015 15” MacBook Pro.
It’s best to focus your inquiries into OpenCore at their site. We try to stay within the hardware and basic OS issues which intertwined.
完成的
@danj -- It seemed that it could be the problem with the iMac itself, not the installer, I tried to upgrade it with Catalina and failed as well, and looks like High Sierra is the most far software it can be installed. Is there a way to check if there is any restrictions set on this iMac?
完成的
显示更多的1条评论
添加一条评论
Hi, I am facing the same problem, did you get any resolution?
这个答案有帮助吗?
得分 0
2条评论:
@diehkitchi - We focus on the hardware side of things and try to stay focused on the OS the system was designed to support. OpenCore Is a tricky beast! As Apple addresses bugs and/or enhances newer flavors of MacOS OpenCore can and often breaks!
You really need to focus your issue with the OpenCore community.
完成的
Thanks for your reply, I got the same prompt but mine said corrupted usb. But the usb seems alright so don’t know what is happening, I guess I have to take it to the openCore community
完成的
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 52
总计 408
