After attempting to clean keyboard, laptop won't power on
Following the directions on removing the keyboard from this site, I dismantled the laptop, removed the keyboard, cleaned, and put everything back together again. Now though, when I plug in my power adapter and press the power switch, nothing happens. No fan, no sound, nothing else.
The status indicator at the front of the laptop never turns on or breathes, and the power adapter's led is green. I've double and triple checked that all the connectors on the keyboard are connected (backlight, keyboard ribbon, trackpad ribbon, and motherboard connection you manually press into place).
I must have disconnected something without realizing, or am not properly connecting one of the ribbons mentioned above. Given my description, does anyone have any hints as to what may be the issue? Under what situations does the white status indicator light turn on?
How far do the ribbons need to be inserted into those connectors? For example the orange one that connects to the trackpad, should it be in all the way up to the black line? I haven't been able to push it in further.
3条评论
I wanted to clean it because certain keys were stuck/not working after a bit of coffee spilt.
由 Nick 完成的
I've attached images of the four ribbons reconnected. Maybe something will stand out to someone with more experience at this. At this point I'm trying to get my hands on a multimeter to start checking connections manually.
由 Nick 完成的
I had a similar problem connecting that track pad cable on my MacBook, but I'm assuming that if you completely removed the topcase you're familiar with the lock mechanism in the connector? Make sure the lock is completely released before you try re-inserting the cable.
由 Majesty 完成的
