跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Power Button & Vibrator Unresponsive
I dropped my iPhone like everyone out there. My power button and vibrator stopped working. Although my headphone jack, mute button, volume control all work fine.
I find it funny that both the power button and vibrator quit at the same time. The ribbon "looks" fine.
Should I just break down and replaced the ribbon?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
As the control for both of those functions is on the same flex it makes sense to replace it. The ribbon is pretty slim and takes a few bends before reaching the connection. it's a bit of a pain to replace though. Is the bezel separated from the rear case? if it is it may just be that the power button is no longer making contact fully, I take it that you disconnected and reconnected the flex onto the motherboard?
这个答案有帮助吗?
得分 3
2条评论:
When it stopped working there was a gap between the back housing and bezel.
I just replaced the glass, digitizer and back housing. There is still a gap from the bezel and new housing. I think of poor quality?
So yes I did disconnect the ribbon from the flex cable to the motherboard.
I'm going to take it apart again and file down some of the tabs on the new rear housing to see if it fits better.
I guess I can just order a new ribbon, but was trying to diagnose before spending money on stuff I don't need.
Thanks
完成的
try loosening the screw near the "do not remove" sticker as it may be pressing on the motor for the vibrate, also check that the prongs on the motor are sitting "up" and making contact with the back of the motherboard.(They can get flattened easily in a transfer) Make sure the little metal cover for the motor is in the rear case properly, it has 2 very small tabs that sit into the rear case which you then screw down. As for the power button, try loosening the securing screws a little, overtightening can keep it always depressed hence it doesn't work. These annoying little foibles may fix the problem so you don't need new parts.
完成的
添加一条评论
添加你的答案
ryno4 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 400
