跳转到主内容
Repair and support for ceiling-mounted bladed fans.
20 个问题 查看全部
Ceiling fan works fine without blades; makes clicking noise with them
Without any blades, our ceiling fan spins silently. When I put the blades back on it makes a clicking noise every time it’s switched on.
I cleaned the blades and made sure that they are fastened properly.
When I observed the fan, I noticed that it’s due ring / bracket that holds the blades and spins is touching the non moving base that houses the light fixture.
How can I fix this?
It’s a Hunter fan with 5 blades. Something that looks like this https://www.hunterfan.com/products/ceili...
Don’t know the exact model because it came with the house we’re living in
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi Sid,
I'm thinking you may need to look at balancing the blades. They're supposed to be manufactured to be exactly the same weight and at precisely the same angle in order to spin with no wobble, but hey, it's not a perfect world and sometimes the blades need some help. There's a longer discussion on the subject in this earlier question.
My fan is moving - Ceiling fan - iFixit
As I mentioned there, Hunter has a video showing exactly how to do the balancing.
How to use a Ceiling Fan Balance Kit - YouTube
Good luck; let us know what you find. Success stories are always appreciated and we can always learn something when it doesn't work.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 146
