跳转到主内容
日产汽车的修理和支持指南。
689 个问题 查看全部
Why my car overheats
Nissan march 2004 model overheats at 100km, why?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hello there,
Without more information all I can really do is guess.
A car can overheat for a few different reasons but the main reasons I have seen are the thermostat is stuck/seized or the coolant needs to be replaced because it is dirty for some reason.
This can lead into other causes of why the coolant is dirty but those are two things it could potentially be.
这个答案有帮助吗?
得分 2
添加一条评论
To add to Lee's possibilities, the coolant level could just be low.
In any event, at higher speeds more cooling is required as the engine is working much harder than it would be at a lower speed, and it sounds like your cooling system can't keep up for some reason.
I ran into a similar situation with my wife's Mazda where it would overheat on highway driving; in that case it turned out the radiator was partially blocked and couldn't provide the full amount of cooling needed. Replacing the radiator turned out to be the fix in that case.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Justin Jere 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 19
