跳转到主内容
这是三星Galaxy Note 20 Ultra 5G Android智能手机的维修和拆解信息。发布于2020年8月。
46 个问题 查看全部
small help for my motherboard note 20 samsung
my phone have problem black screen and touch work
iam sure the problem is backlight ic
but i dont where place on my motherboard can anybody help me
that some picture:
plate the screen:
https://guide-images.cdn.ifixit.com/igi/...
plate motherboard and some extra plate:
i just what know the place backlight ic to fix it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @madisonjfry
I don't think that there is a separate backlight IC as such.
According to the specifications the phone has an amoled display.
Amoled displays are different to LCD displays in that the individual pixels produce their own light so separate backlighting is not necessary. The pixels are either turned on or off.
Here's a link that describes it better than I can, that may help
Update (06/06/23)
Hi @madisonjfry ,
Perhaps check if the display cable is securely connected first.
Here's the no display troubleshooting flowchart from the service manual that may help to know whether it's a display problem or a systemboard problem.
Unfortunately the manual is not quite complete as it doesn't show the location of all the components mentioned as test points. -
I only found one i.e. U10001. Here's an image of the board that it's on to show its exact location on that board.
(click on images)
Update (06/06/23)
Hi @madisonjfry
Here are the Samsung part numbers for the complete display modules for the model. It seems that there is more than one part number for the same part as searching for any of the part numbers for a variant gives the same result. Search online using the part number only to find suppliers that suit you best
Samsung Galaxy Note 20 Ultra (SM-N985F SM-N986F)
Display unit complete mystic white GH82-23622C GH82-23597C GH82-23621C GH82-23511C GH82-23599C GH82-23596C
Display unit complete mystic black GH82-23622A GH82-23597A GH82-23621A GH82-23511A GH82-23599A GH82-23596A
Display unit complete mystic bronze GH82-23622D GH82-23597D GH82-23621D GH82-23511D GH82-23599D GH82-23596D
这个答案有帮助吗?
得分 1
4条评论:
so i must replace full screen? to fix this problem?
完成的
yes all is fine connected
when the display take black i on bed watch youtube then go to black and the sound still on ( but phone very hot before screen do to black)
so i think is no problem with cable
完成的
@madisonjfry
The display is not cheap to replace so I don't know what the best option for you is.
Getting hot is not good but it could be that the display is the cause of this problem or maybe not.
Perhaps it may be better to take it to a reputable , professional authorized Samsung repairer and get it checked out. They may have compatible displays available that they can temporarily connect to find out. Also they can test the board to see if it is the problem.
完成的
any idea from where can buy screen good quality?
i check alixprees all bad quality
完成的
添加一条评论
添加你的答案
Madison J Fry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 156
