跳转到主内容
This device is a Non-Contact Voltage Tester Pen, with acceptable range from 50 to 1000V AC.
1 个问题 查看全部
New Klein NCVT1P no test sound
My new Klein NCVT1P responds correctly to turning on and off with lights and beeps but makes no sound when testing a known good circuit.(the red led illuminates but no sound) Is there a switch to change it from silent to audible notification of voltage?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @timmcintyre
According to the user guide there is a silent mode
"The tester can be operated with only visual indication of voltage. With the tester powered off, press and hold the power button (4) until the green LED (2) illuminates, then release."
If it is disabled then perhaps performing the same procedure will enable it, it doesn't say.
If not, return it for a replacement or a refund
这个答案有帮助吗?
得分 1
添加一条评论
Turn the tester on by pushing the button and immediately releasing it. Don’t wait for the audible beep as happens when you hold the button to turn it on. Simply press and release
这个答案有帮助吗?
得分 0
2条评论:
i’m having the same issue you’re supposed to hold down the ncv for two seconds but mine still isn’t audible
完成的
For sound mode you have to press the power button for a brief second then release. Check out my video above.
完成的
添加一条评论
添加你的答案
Tim McIntyre 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 26
过去 30 天: 123
总计 1,007
