跳转到主内容
Seventh generation of iPad, released September 25, 2019, available in 32 or 128 GB models. Model Number A2197.
46 个问题 查看全部
ipad 7 no life, charging at 0.08 amps
I bought a broken iPad 7 off the Facebook marketplace. I thought it would be a fun and educational project.
It has shown no signs of life. Replaced the battery, and still has no signs of life. I purchased a USB voltage monitor and tested the charging. It is getting 0.08amp of power draw when plugged into a known good charger. Is this a charging port issue or a possible mainboard issue? or something else?
What are some tests I can perform to diagnose this?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
download a program called 3utool on a pc/laptop, connect the ipad to the computer after installing that check if the ipad is in dfu mode. if it is you can use the program to try exiting dfu but if it goes back to dfu mode or even shows connect to itunes etc it could be a board issue as ipad 7 has a problem with the cpu disconnecting and needs reballed
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Cooper Goswick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 24
总计 183
