跳转到主内容
Apple的9月20日发布的Apple主流2019 iPhone带有6.1英寸LCD触摸屏,双摄像头和六种可用颜色。iPhoneXR的后继产品。
475 个问题 查看全部
Post repair no lte data or I message
Post repair screen repair on an iPhone 11 on newest ios version, everything seems to work expect for any internet connection wifi 4g lte / 5g
The device indicates 4 bars lte data service and can make phone calls without any issue
However I message safari or any other network connection simply doesn't work.
These are the troubleshooting steps I have taken
Reboot soft and hard
Reset to factory network settings
Reset all settings to factory defaults
Enabled and disabled airplanemode
Reseated all logic board fpc connections
Replaced the screen with another new screen just incase
Unplugged the battery for several minutes
The phone other than the damaged screen I replaced is in perfect psyhical condition no signs of dust dirt corrison scratches dents or anything
My prognosis is this is a software issue of some sort.
I had my coustmer factory reset the device will update with results.
Have any other technicians experienced this issue post repair?
The mobile data functioned prerepair...
Switching to the old display did not have an impact.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
SLOVED - - the date had reset to January 1 1960 and Web services denied all traffic. The phone lost rtc clock power Long enough for ram to flush.
Manual date and time adjustment corrected the issue.
这个答案有帮助吗?
得分 0
3条评论:
😂😂😂😂😂😂 easily done.
完成的
Be sure to accept your own answer so people with this same problem will know you found a solution.
完成的
@dadibrokeit done and thank you
完成的
添加一条评论
添加你的答案
DanielAdvancedDeviceRepair 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 39
