跳转到主内容
13 英寸 MacBook Pro 于 2020 年 11 月发布,配备 Apple 基于 Arm 的 M1 SoC,具有 8 核 CPU 和 8 核 GPU。(型号 A2338 / EMC 3578,带有两个 Thunderbolt 3 端口)
115 个问题 查看全部
swapping logic board of the same model but different ram and ssd size
I have broken screen and broken touchbar macbook pro m1 model A2338 with 16g of ram and 1t of ssd, is it possible to swap my logic board (motherboard) with any other model A2338? will I have ANY compatibility or paired issues with the swapped case like the true tone, touch bar, and touchpad?
Thank you for your answers.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
As long as you transfer the power button (TouchID) with your logic board.
Be very careful! If you damage the ribbon cable that’s the end of your logic board as it’s married to it.
这个答案有帮助吗?
得分 1
2条评论:
Thank you very much @Dan
完成的
@herve361 - Don’t forget to accept the answer if you’re set - Thanks!
完成的
添加一条评论
添加你的答案
herve 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 51
