跳转到主内容
加入维修社区 - 创建账户
任天堂于2019年9月20日发布了在Switch系列中更加实惠、且更纯粹的掌上游戏机——Nintendo Switch Lite,它有着一体式的手柄设计以及更小的屏幕。
Replacing Right Shoulder Button
Hello!
I was performing a stick swap to fix a drifting joystick on my switch lite. During that, the exposed rubber for R button ripped off when removing the plastic bumper. I've only ever soldered a couple things, and I'm having issus getting the solder to melt. I've got new buttons, but the repairs I see are all for joycons and they don't seem to have issues with the solder not melting.
Has anyone performed this kind of repair or have any advice to get this button swapped out?
A photo of the broken button is attached.
Any help is greatly, greatly, appreciated.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
What solder are you using? Use 60/40 leaded. Also what soldering iron are you using? Add a pic if you can. Also use flux. It helps with the transfer of heat allowing the solder to melt.
这个答案有帮助吗?
得分 0
2条评论:
Thanks for the reply! I had my soldering iron set too low. I originally found 260° C was a good temperature, but after looking again I saw 360° C was recommended. I changed my iron to 360° C and I was able to melt the solder and get the button off. I had an issue with the through holes, but since they were only there as supports, I was able to remove (tear) the button portion from the support mounts. After that I resoldered a new button the the data pins and supports mounts and everything has been working great for about a week now. If anyone else needs to do this, make sure you resolder the button as close to the board as you can. The space to fit the shoulder button is very tight.
完成的
Hello, for the replacement part? Does a joy con part works as well? (The bumper R solder part)
完成的
添加一条评论
添加你的答案
Brandon Paul 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 26
总计 1,801
