跳转到主内容
加入维修社区 - 创建账户
iPad Pro 5th Generation won't boot black screen, limited amperage draw
The iPad suffered impact that shattered screen. The amperage draw is continually .48, far below normal, regardless of how long it has been left on the charger. The charging port has been replaced and tested with no change. The screen has been replaced as well. The screen is black and there is no evidence it ever boots. Have tried soft reset (vol up, vol down, power). No change. New MFI cables and chargers have been tried. It will not mount for wipe/restore. Does not appear visible to external devices.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Did the device function before the screen repair?
I know the iPad pros need a lot of juice to charge. Have you tried any fast chargers?
Did you disconnect the battery while replacing the screen? If so, double check to make sure you have the battery screw securely in place. If you didn't disconnect the battery, you might've caused damaged to the board. Or if you pried between the battery connector you could've damaged that as well.
这个答案有帮助吗?
得分 0
1条评论:
No, the customer brought it to me functioning this way. It's currently on a fast charger, but hasn't changed in symptom.
完成的
添加一条评论
添加你的答案
jparks 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 207
