跳转到主内容
Brief one or two sentences with identification info. Example: Released June 2009, identified by model number A1303.
17 个问题 查看全部
Charger and power indicator.
My laptop is critical low battery. When I plug in the charger the charging indicator will blink 3× times then power indicator which is blue blink and then they blink at the same time. What is the possible problem and the solution. Thanks for the answer.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I have the same issue in the laptop. Mine is because I've used the charging port badly. It will probably need a change of the port.
Also, my fans turn up and down without any reason, and doesn't for a while when a game is being played- get's heated until I turn fans to max in NitroSense.
I don't know if that's related to the charging issue though.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MASHEEET 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 99
