Will the HP Touchpad still turn in without the battery
Recently my HP Touchpad’s Battery swole up so I had to remove it but I didn’t get a replacement battery, I was wondering if the HP Touchpad will still turn on when connected to the original power adapter and cable.
All you can do is try it.
由 [deleted] 完成的
@strongbow could this end up damaging it, because that was my primary worry.
由 TechVid 完成的
@techvid I wouldn't of thought so. I connect mobile and tablet boards after fitting new charge ports to make sure the soldering is done correctly.
由 [deleted] 完成的
@strongbow ok thanks for letting me know, i will try that and get back to you.
由 TechVid 完成的
