跳转到主内容
Laptop only boots when you do a hard SMC reset
From what the eBay seller of the system tells me:
Laptop only boots when you do this:
  • Unplug power
  • Hold power button down
  • Connect reconnect power
After a few seconds it will chime, then let go of power button
Note it will run with fans at 100% the whole time. Also battery is dead, so if you unplug power, it will shut down. I found this tip on here on iFixIt.
Not sure what is wrong with the laptop, had previously thought it was dead and unable to boot, but it can when you do the above. I have tried SMC and PRAM resets to no avail.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
This sounds like it could just be a dead battery. See what happens if you disconnected the battery and try to power up.
这个答案有帮助吗?
得分 2
1条评论:
I will let you know when I receive the device I ordered it on Ebay I just posted it so I can get some answers
完成的
添加一条评论
添加你的答案
Maimlian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 145
