跳转到主内容
加入维修社区 - 创建账户
2016 款 Kia Optima 于 2015 年底上市。它与 2015 款 Hyundai Sonata 共用平台,并采用了全新的设计,同时增加了新的功能和改进。
My oil light comes on only when braking
After the car has been driving a little from time to time the oil maintenance light comes on when braking the car was bought used and service isn’t due yet on it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi @melissaquijada,
Have you checked the oil level in the engine, you didn't say?
由完成的 分享
添加一条评论
1个答案
已选择的解决方案
Hi Melissa,
Your car should normally have about five quarts of oil in the engine, and there's a pump that pulls oil from the pan. When the oil level is low, the oil can slosh from one side of the pan to the other and leave the oil pickup dry, which then turns the oil light on. When you come to a stop, the oil sloshes back to the low point of the pan and continues to get sucked up by the pump.
So basically your car is low on oil. Pull out the dipstick, wipe it off and put it back in. Now pull it out and see where the oil appears on the markings. If no oil appears, you're really low, otherwise the low mark shows when you're about a quart low. Add oil until the oil comes up to the full mark and you should be good.
Without knowing the year and engine size of your Optima I can't tell you exactly how much oil it should have, but generally a total of 5 quarts of 5W-30 is enough to refill it from completely empty.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Melissa Quijada 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 25
过去 30 天: 82
总计 3,765
