跳转到主内容
Smaller version of the original iPad Pro. Released March 31, 2016. Features a 9.7" display, A9X processor, and 32/128/256 GB storage options. Available in Silver, Space Grey, Gold, and Rose Gold.
147 个问题 查看全部
iPad screen issue after battery replacement
I replaced the battery of my iPad pro 9,7 inch (2017). After reconnecting the screen, I turned on my iPad and found the screen not working (please refer to the attached picture). Any idea on what causes this issue? The screen connectors on the logic board and the ribbon cable do not seem damaged, so I am wondering if a replacement screen should fix the issue. Could I maybe have damaged the screen whilst removing it from the iPad?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Looks like you've damaged it. New screen unfortunately. Not cheap either.
这个答案有帮助吗?
得分 2
2条评论:
Yeah I think so too. But in the end with the new screen its probably going to be less expensive or similar the amount I would have to pay a shop to do a battery replacement. I decided to try it because it's an older device anyways and I got to learn something out of it. Better luck next time!
完成的
Battery replacement is a lot cheaper than a replacement screen on a ipad pro unless the shop you go to is a rip off merchant.
完成的
添加一条评论
添加你的答案
Patches90 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 100
