跳转到主内容
加入维修社区 - 创建账户
沃克斯豪尔汽车的修理和支持指南。 成立于1903年的英国汽车品牌。
Why does my window not close?
When I look the vehicle the passenger window goes up and goes down and stays down
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @kimcele,
What is the year and model name of the vehicle?
Also which passenger window, front or rear?
How do you make it go up when you say it won't close?
完成的
添加一条评论
1个答案
Common problem with the Body Control Module (BCM) on this one, and quite a few others too. The quickest way is to buy a change-over unit from a parts supplier (repaired, tested and under a good warranty - and cheap enough). I wouldn't recommend second-hand, as these are a common problem. If you want to repair your own, you'll need a de-solder station & soldering iron with adjustable temperature. Re-work any dry joints you can find (especially on connectors and relays) and clean out the PCB relays (difficult to get exact replacements for). Use a strip cut from thin card and pinch it gently between the relay contacts while drawing it through until you can't see a black carbon trace on the card any longer. I've personally fixed hundreds of these and many more like them. If you need help repairing, post photos of both sides of the BCM PCB.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kim Cele 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 18
总计 109
