跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
LCD is stained. Looks like humidity
iMac midi 2007 is working but the LCD is stained. Looks like humidity.
the Mac was unused for a while.
Update (05/24/23)
I thought that was it too. I took the glass off and cleaned it and nothing changed. I turned on my Mac without the glass and the smudges keep showing up all over the screen. as if it had moisture behind it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Follow this guide iMac Intel 20" EMC 2133和 2210 玻璃面板更换 as it’s likely the cover glass back side that needs a cleaning.
Update (05/25/23)
Well… that only leaves mold buildup on the defuser sheets or just a worn-out LCD as the liquid crystal material used in these older systems loose there ability to toggle effectively as the areas have a persistence issue as the background image was too static. The last possibility is this series used CCFLs instead of LEDs and they too over time and use wear out.
If you can find a good used display assembly I would just replace it, if not you may need to live with it.
While you can get to the sheets to clean, you may end up with a bigger mess as cleaning can leave streaks which become visible. The CCFL’s are getting hard to find as they hold Mercury vapor
Which why it’s just better to replace the assembly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
norberto 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 130
