跳转到主内容
Why does my heating shield make noise
It makes a rattle noise from heating shield , every time I accelerate car
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Be more specific, what Fit what specs what noise.
完成的
添加一条评论
1个答案
One or more fasteners are loose or missing. Another possibility is the heat shield is bent reducing the clearance require to prevent a rattle. this should be a quick and easy repair that will cost you less than $100. A third possibility is a broken exhaust hanger that allows the exhaust system to move far enough to contact the heat shield. One more possibility is a broken or wore out engine mount. If engine movement is excessive that may allow the exhaust to contact the heat shield.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
LiL Ivan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 57
总计 313
