跳转到主内容
Repair information and troubleshooting for the Dell Latitude E6430. This business class laptop has a 14 inch screen and uses a 3rd generation Intel Core processor. It was announced in May 2012.
9 个问题 查看全部
How do I remove a stripped screw for the wifi card?
I recently bought a compatible wifi-6 card for a Dell Latitude e6430 that I've been steadily upgrading as my mother's personal computer.
I've done every upgrade I could at this point aside from the wifi card. My issue is that the screw holding the wifi card together is incredibly tight, and heavily stripped (O-shaped). I've already tried the rubber band, a precision rotary pen, and small screw extracting pliers which were too big to work with.
Any suggestions for removing and replacing this wifi card and screw would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Dolos,
iFixit makes a set of screw extracting drivers that might be worth considering to get that stubborn screw out.
Precision Screw Extractor Set: Small Stripped Screw Remover
You could also try drilling off the head of the screw; at that point the circuit board should lift off the shaft at which point you would hopefully be able to once again get pliers on the shaft of the screw to turn it out.
As strictly a last resort kind of remedy if you absolutely cannot get the board out any other way, you can always take some wire cutters and cut away the circuit board around the screw. This, of course, will destroy the existing WiFi board, but if you're replacing it anyway it would allow you space to get a pair of pliers on the head of the screw to remove it.
These last two are pretty much desperation measures, but may be necessary if you've gotten to that point.
Precision Screw Extractor Set图片
产品
$24.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dolos Kurosu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 41
总计 303
