跳转到主内容
加入维修社区 - 创建账户
This Audi A6 model received a facelift in 2001 for both sedan and Avant versions. The revised A6 sedan featured a new grille design and different headlights, while also being fitted with a wide range of petrol and diesel engine configurations. Most of these powerplants received a boost in power outputs.
Interior lights don't work
Interior lights and button to lock the doors don't seem to work. I just bought this car second hand. However Window buttons do work. Also button to open trunk doesn't not work. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
@corneliousj5992 What model year is the car?
完成的
Hi Andrew it's a 2004
完成的
@corneliousj5992 Have you checked that the fuses are all good?
完成的
No, I'm not sure how to check or which one to look for.
完成的
添加一条评论
2个答案
  1. Check fuses (Info at the cover of the fuse box) or just replace the broken one ;-)
  2. Check the door sensor if it recognizes door(s) state (open/closed). maybe disassembly is nessesary
  3. Check button and interior lights by measure powersuply if car is started or key is in pre-ignition position
  4. If VCDS diag system is available. You can check for erros in one of the control units
additional infos, schematics, exploding drawnigs can be gained via erWin of AUDI - erwin.audi.com
这个答案有帮助吗?
得分 0
1条评论:
Thanks! I'll give it a shot!
完成的
添加一条评论
нужно осмотреть блок предохранителей,и под ковром,со стороны водителя есть блок комфорта ,если во время езды из дна машины выпала заглушка,то вода могла попасть внутырь и намочить сам блок. а он отвечает за множество функций ,центральный замок,освещение салона,настройка длительности освещения.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cornelious Jordan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 47
总计 434
