跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
704 个问题 查看全部
Nintendo switch wont wake up from sleep mode only when charging
I have an issue with my nintendo switch (2017 model) and i was wondering if you could help me with this. I just replace my frontal switch shell and everything is okkay and working fine except one thing, my switch now wont wake up from sleep mode ONLY if charging. If i put my switch on sleep docked or charging with the ac adapter (the original one), after 15-20mins if i try to turn the console on it just wont wake up and i have to hard reset and then its working perfect again. The console wakes up normally if there is no dock or ac adapter connected. Do you know what can cause this issue?
Actualización (05/21/23)
BTW the dock and ac adapter is working fince since i tried with another switch and no problem.
Update (05/22/23)
I noticed that there is a couple of pins bent on the lcd connector.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
That's probably the problem. Try a new LCD and see if that fixes it.
这个答案有帮助吗?
得分 1
1条评论:
I tried with a new LCD screen and it doesn't fix it. It is probably the connector, but I'm afraid trying to fix it since I never did anything similar before.
完成的
添加一条评论
添加你的答案
Francesc Rodriguez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 246
