跳转到主内容
2020年4月宣布和发布的第二代iPhone SE的维修和拆卸信息。
243 个问题 查看全部
SE2 truetone and front cam questions
1) does true-tone operation require that the front camera be connected?
2) can a malfunctioning front camera prevent a phone from booting?
in this case, the boot cycle stays locked at the apple logo, when the front cam is disconnected it boots fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi B C,
I can't speak authoritatively for the SE 2020, but I can tell you for sure that a bad camera on an iPhone 7 Plus can keep it from booting. I had to replace the camera assembly to get the phone to work again; same symptoms, it worked when the camera was unplugged and putting in a new camera fixed it.
I don't think the camera is required for True Tone, but the ambient light sensor probably is. Since they're on the same connector there's no way to tell which would be the cause of the problem.
Definitely time for a new camera. Fortunately it won't break anything on the SE 2020 to replace it, at least as far as I know.
这个答案有帮助吗?
得分 4
2条评论:
@dadibrokeit
Hi Jerry,
you are definitely correct the front cam flex being required. however, i think it is looking for the the matched camera ID because connected a different SE2020 front cam flex. it booted, but no truetone (the base screen was original). so at this point, i'm not sure that replacing the camera flex will fix the truetone problem. my JC V1SE can restore truetone to the LCD screen, but it doesn't have a board to reprogram the ID of the camera flex. :(
i think i've lost true tone on this phone, but i'll keep digging.
Thanks
完成的
According to fixez.com, the front camera assembly consists of the following components.
Includes the 7 MP facetime HD front-facing camera and microphone.
Also contains the ambient light sensor and proximity sensor.
We know that the ALS and proximity sensors are paired on phones with Face ID, so it's entirely feasible that they could have paired either one or both on the SE, but why? There's no security issue here so it's no more necessary than it is to pair a battery.
完成的
添加一条评论
添加你的答案
B C 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 175
