跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly information for the Logitech MX Master 3 wireless mouse. Released in 2019 and identified by model numbers MR0077, 810-006815 (Europe), 910-005620, 910-005647, or 910-005692.
Grey housing turns ugly very fast. Please support replacement Parts
The grey housing on the MX Master 3 looks amazing but turns yellowisch and ugly in just a few month with sweaty hands. The housing is probably one of the cheapest parts to manufacture.
Could you please support a change of the outer housing of the mice?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 13
4条评论:
Same mouse, same problem. This basically happens with any mouse that has a bit of a rubber surface.
完成的
I'd also buy a replacement upper housing if available.
完成的
If Logitech wants me to actually take their "repair, don't rebuy" posturing seriously, this is a must. My mouse functions perfectly, but the soft-touch rubber has degraded over the years and is sticky to the touch. Please support us replacing the shell. There are some floating around on ebay now, but they're 50$ per piece and without official instructions, which does not seem reasonable to me.
This will basically decide whether I keep buying Logitech products or say goodbye to fancy smooth scrolling and go to a company that lets me keep my electronics out of the landfill.
EDIT: That said, kudos for starting this repair initiative at all. Do this right and you'll have a lot of trust and recommendations from my end.
完成的
I have the same problem with the black one, but this material is indeed more skin-friendly.
完成的
添加一条评论
1个答案
I have the same problem with the black version, although this material is indeed more skin-friendly. Currently, there's no solution to this problem. I recently purchased the RAPOO MT760 Pro, which has a similar appearance to the MX Master 3. Its mold is very similar to the MX Master 3, but the casing uses a different material, so it doesn't have this problem.
https://www.reddit.com/r/MouseReview/com...
https://shop.rapoo.com/products/rapoo-mt...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
FusterCluck 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 47
总计 665
