跳转到主内容
The second generation Pathfinder was introduced in late 1995 with more rounded styling. It was completely redesigned from the first generation, switching from body on frame construction to unibody construction.
15 个问题 查看全部
Rear Wiper Arm Wont Park
my 2002 Nissan Pathfinder rear wiper wont park back into its place after running it, and when its turned off, it makes a humming sound every few seconds until i manually go to the back and put it back into its saddle/parked area. how do i fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
https://www.youtube.com/watch?v=C3MXmBwN... seems to be the right youtube with the answer.
Update (07/07/24)
So it turns out all I needed to do was twist the arm a little bit and now it parks just fine.
这个答案有帮助吗?
得分 1
添加一条评论
The motor is most likely burnt out. That'd explain the repeated humming sound. Try replacing it.
这个答案有帮助吗?
得分 0
2条评论:
thanks! i will consider trying that, any idea how to replace the motor?
is there a how-to on this?
完成的
完成的
添加一条评论
添加你的答案
Ezra 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 68
