跳转到主内容
这是 MacBook Air的维修指南,MacBook Air是Apple的一款面向消费者的笔记本。
4820 个问题 查看全部
问题已关闭
When I restart my computer Grey screen with restart message
My computer was running slow. I had not shut it down for several days. I went to shut it down and it gave me a grey screen with the spinning wheel. This lasted for a few hours. I then used the power button to shut down the computer. When I restarted, It showed a grey screen I hear one start-up chime and then some (DOS Language) in the background with a black box in the foreground stating I had to restart My computer by holding down the power key until it shuts off and then restart by pressing the power key once again. Sorry for the run on sentence. I tried this several times, Shut down and restart, all with the same results. Any suggestions.
Corey
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thank you guys for your comments and suggestions. I am away from home and will take a few days to try out your ideas. I just wanted to let you know I got your messages and wanted to thank you. I will post the results when I can get up with my reboot disk.
Corey
完成的
添加一条评论
2个答案
已选择的解决方案
This is called a "Kernel Panic". It means that the operating system found a condition where it can't go any further. Could be hardware or software related.
Try starting up the computer from the installation medium (CD or thumpdrive) and either try installing new from scratch, or repair the disk via "Disk Utilities", found on the second screen in the Utilities menu.
If you still getting a Kernel Panic when booting from an external medium it might be a hardware failure.
Please report your findings.
这个答案有帮助吗?
得分 3
3条评论:
I would remove and reinstall the memory--thats what I usually find causing kernel panics. +
完成的
You're right rj - but on a MacBook Air the RAM is not changeble but soldered on to the logicboard. In that case - bummer.
完成的
Now how did I miss that--to quote Gov. Perry--oops.
完成的
添加一条评论
some times the peoblem will be the hard drive gane the hard drive and boot new windows in
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 1,927
