跳转到主内容
PlayStation 3 Slim是PS3的第二个迭代机型,机器型号CECH-2000。索尼电脑娱乐推出此机型来修复初代“胖机”PS3的诸多硬件问题,于2009年9月1日发布。
Why is my pa3 not recognizing disks?
When putting in a disk it pulls it in normally but then keeps pulling it in the same way it would if you took the disk out after touching the sensor inside the reader. After it's done overly sucking it in the ps3 doesn't recognize the disk.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
  1. Dirty or faulty disc drive sensor: The sensor inside the disc drive that detects the presence of a disc may be dirty or malfunctioning. Try cleaning the sensor with compressed air or a soft, lint-free cloth. Be gentle and avoid applying excessive pressure.
  2. Disc loading mechanism issue: There might be a problem with the loading mechanism that pulls the disc into the drive. It could be misaligned or worn out. In this case, you may need to have the disc drive repaired or replaced by a professional technician.
  3. Firmware or software issue: Occasionally, firmware or software glitches can cause disc recognition problems. Ensure that your PS3 is running the latest system software version. You can try updating the firmware or performing a system restore to see if it resolves the issue.
  4. Disc format or condition: Make sure that the discs you are inserting are compatible with the PS3 and are in good condition. Scratched or damaged discs may not be recognized properly. Try using different discs or cleaning the discs if they are dirty.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Conner Heidecker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 95
