跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
170 个问题 查看全部
Why is my ping goes very high when playing csgo?
Every time I go on a faceit match my long goes 500-600ms
My ping goes high for 2 or 3 rounds every match
It is very annoying
My average ping on csgo is 60
My average network speed is 100 mb/s but when the ping goes high for ~5 min my network speed is 5 mb/s
I someone tell me how to fix this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Could be your CPU and/or GPU being outdated or insufficient for running CSGO. Could also be that too much RAM is taken up and you need to clear up some storage.
这个答案有帮助吗?
得分 0
添加一条评论
Ping is a network parameter. It measures the time it takes for your ping to go to the target and back. It doesn't have anything to do with your computer. You might want to do a tracert or traceroute to see where in the path the delay is. Ultimately, there is nothing you can do about it.
https://support.n4l.co.nz/s/article/How-...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kozeriukas lt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 82
