跳转到主内容
加入维修社区 - 创建账户
发布于 2020 年 11 月 6 日。 型号 LM-K920
LG K92 5G- I have Questions about Power Flex Cable Replacement
I would like to know if you have a guide for replacing the power button/finger print scanner. The screen repair guide helps but im curious if there is anything I should know about it. The phone turns on when plugged in showing it is charging, but when the power button is pressed the phone doesn't turn on. I have the new power button in and have stopped there, but was curious and had concerns of things that I may need to do or avoid doing. Also if replacing this should fix the issue.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I didn't figure out why the power button doesn't work, but I saved the customer money and showed him how to turn it on. If your power button doesn't work on any LG phone this is what you do to turn it on. Hold down your volume down button, plug your phone into the charger as soon as you see the LG come onto your screen release the volume down button and unplug your phone from the charger!
这个答案有帮助吗?
得分 1
2条评论:
Thanks! Worked on first try!
由完成的
Yea! Glad I could help you out! Took me hours to figure it out!
由完成的
添加一条评论
添加你的答案
Zach Benson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 434
