跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
374 个问题 查看全部
Replacement keyboard from MacBook Air A1369
I was wondering my mid-2012 MacBook Air A1466 keyboard does work and I was wondering if I can fix it with a keyboard for a MacBook Air A1369? Just wondering if two different model are interchangeable for the keyboard to fit.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
There are a few different issues you face. If the system a North American or a European system? And if European you have a few possible key caps with different language symbols.
Ok so let’s assume you have a North American system then you need the proper keyboard for your system as each series have different setups. Here’s the correct part MacBook Air 13" (Mid 2011-Early 2015) Keyboard. Sadly the older late 2010 keyboard won’t work here.
Its a fair amount work as you need to strip the system down quite far. So be prepared!
MacBook Air 13" (Mid 2011-Early 2015) Keyboard图片
产品
$29.99
这个答案有帮助吗?
得分 1
6条评论:
It’s an American keyboard that is a 13” A1369 keyboard. So that will work then?
完成的
@jordanchapman - Not if it’s a 2010 model
完成的
So if it was a 2011 model then it will work?
完成的
@jordanchapman - I don’t remember if the 2011 models used screws. I think this was the first series to use rivets. So if it has the rivets then you end up destroying the keyboard taking it out.
I would check things before going to far.
完成的
If everything seems right then it’s alright to install it then?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Jordan Chapman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 99
