跳转到主内容
加入维修社区 - 创建账户
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Backlight died on my MacBook Pro Retina 15" mid-2012
Hi all,
My MacBook Pro Retina 15" mid-2012 "died" the other day while I was using it. Or so I thought, until I shone a flashlight through the Apple logo and I saw that the screen was working fine -- just the backlight was dead.
I tried to connect it to an projector, but that didn't work -- could it be that the GPU is dead, not just the backlight? I have a model with an Nvidia GPU and switchable graphics.
Interestingly, I left it for dead for a few weeks, then decided to open it. I didn't do much -- dedusted, pressed on one of the screen cable connectors, then disconnected the battery for 2 minutes and connected it back.
Eureka, it worked again! Backlight and all! (Didn't test connecting to a projector). But then, maybe a day later, it broke again, screen works but backlight doesn't (and again didn't check if connecting a projector works or not).
Some more info:
  • 2 years ago it fell ~15 cm (6 inches), and one of the fans started to make noise. It's still noisy but the laptop has been working fine for 2 years.
  • On the day the backlight died the first time, the table was wet. I put it on the wet table around noon. It worked until ~10pm that night, then the backlight died.
  • None of the water damage detectors inside were colored.
I'm fine with leaving it for dead, but the fact that it came back to life for a day makes me think there might be an easy fix. Is there anything that comes to mind?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sounds like there is possibly a lose component inside that is sometimes making a connection...or corrosion has impacted the circuitry. It would need someone to examine the board under a microscope with voltage testing equipment to see if any component has come lose or the solder has cracked etc.....
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
alxlive 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 26
总计 238
