跳转到主内容
Repair guides and documentation for the Google Pixel 6a with 5G smartphone. Released in July 2022.
42 个问题 查看全部
Why is my phone won't turn on & can't connect with usb charging?
this happen while i am charging my pixel with off/turn off condition (22% live battery) , but suddenly when i'm checking back arround 30 minutes there is no sign of charging percentage and wont turn on when i press power button, or button combination in terms to restart the phone. any suggestion please? im very confuse right now. hope you can help me. thank you very much.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi Djaka,
In most cases where there's an issue charging the phone, the problem usually comes down to either the battery or the charging port, assuming you've verified that your charger and charging cord are both working. On the Pixel 6a you can help pinpoint the source of the problem by setting the phone down on a wireless charger. Since the wired and wireless charging use completely different circuits, that will tell you where the problem lies.
If the phone charges fine wirelessly but not when plugged in, then you've most likely got an issue with the charging port. Unfortunately, on your phone the charging port is soldered directly onto the motherboard and will require somewhat specialized microsoldering expertise and equipment to replace, so this would be a job to take it to a shop for.
On the other hand, if it doesn't charge with the wireless charger either, then that tends to point to the battery as the likely source of the problem, so if this happens and it was mine, I'd try replacing the battery as the first step toward fixing your phone. Here's the guide you'll need in order to do the job yourself.
Google Pixel 6a Battery Replacement - iFixit Repair Guide
You can also buy a genuine Google battery right here on iFixit as well; I'd recommend the Fix Kit, as it comes will all the tools and adhesives needed to do the job right.
Google Pixel 6a Battery - Genuine
Good luck; let us know how it goes!
Google Pixel 6a Battery - Genuine图片
产品
$32.99
这个答案有帮助吗?
得分 3
添加一条评论
This is the same thing that happened to my Google Pixel 7 Pro what fixed mine was the charging port was completely bad and I unknowingly kept plugging it up thinking its not my port by me doing that I fried my battery and the last bit of my charging port. So overall check the charging port and battery. Hope this helps. :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Djaka Arrazaq 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 140
