跳转到主内容
Weird problems on my Alexa Echo Dot 4
Recently, my echo dot just stopped and started flashing blue suddenly again and again, for the whole night. When I woke up , I realized it was off(like absolutely off nothing was on and it wasn’t responding). I tried to reset and unplug but to no avail. Finally, I decided to open it up. After opening everything and reassembling everything it is working fine except for 3 BIG problems. Volume up button doesn’t work, the Alexa button doesn’t work, and it doesn’t respond(mic is dead). Idk how this happened. I’ve opened up a lot of tech stuff and never messed it up.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Have you checked the ribbon cable between Motherboard and control board? Did you reseat it properly? While prying did you destroy any components?
If all of these are not true, may be see the control board under a microscope and you can find if some contact of a component is not soldered properly.
Even very experienced people sometimes make mistakes. Just take a look of the FPC connectors for the ribbon cable under a microscope. Even a single bent pin would create such disconnected problem. Also check the FPC ribbon cable if there are any tears. I have damaged a Logitech G Pro Wireless cable by accident and the crack was only visible under a microscope. Fortunately you can get the replacement ribbon cables if you search properly and based on the pitch of the cable on AliExpress or eBay.
这个答案有帮助吗?
得分 2
3条评论:
Thanks, it turns out that cable connecting the control board to motherboard wasn’t pushed in. 😂
完成的
do you know any supplier where i can find those flat cables to buy for replacement? it happens that one of them is ripped.
完成的
My comment is too late but there's no simple way to find a supplier. You have to have a calipers and measure the pitch if the FPC cable. Then open AliExpress or eBay and start searching for the keywords like FPC Cable 0.5mm pitch etc. you can also add in number of pins like 6 pin cable or 10 pin. Check of suitable length in the description and probably this search would take 1-2 hours easily to find right cable. Longer cable is fine as it can be tucked but shorter wouldn't suffice.
完成的
添加一条评论
do you know any supplier where i can find those echo 4th gen flat cables to buy for replacement? it happens that some of them are ripped.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
h_man08 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 46
总计 587
