跳转到主内容
28 Inch Top-Load Washer with 4.8 cu. ft. Capacity, 13 Wash Cycles, 4 Temperature Settings, PowerWash System SmoothClose Glass Lid
5 个问题 查看全部
Drain pump continuously runs and runs
Drain pump wouldn't stop running no matter what I did I took apart the washer and found a washcloth clogged in the drain filter. Removed it along with any other debris and cleaned everything down. Check for clogs on all the hoses and elbows. Put everything back together and the drain pump continues to run no matter what I do. I don't know how to determine if it is the pump itself that needs to be replaced, the control board , the water level sensor or something else entirely. Any advice or suggestions would be greatly appreciated. I am stuck.
I went through Maytag diagnostics it runs to C1 - fills the washer with water and then stops completely.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @anthonyfab28396
Here's the tech sheet for your washer
On p.1 it shows the causes for a C1 error code.Since it is filling OK check that the water temp is OK (install manual shows the hot water supply needs to be120F) and also that the basket has lifted.
这个答案有帮助吗?
得分 1
2条评论:
I changed the model I had. This is an issue with my washer. Maytag MVWB880BW Bravos XL
Manual: https://www.manua.ls/maytag/mvwb880bw-br...
完成的
@lilmink777
I've edited my answer above to link the correct tech sheet for your washer and what to check to find the cause of a C1 error code.
完成的
添加一条评论
添加你的答案
Anthony Fabiano 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 58
总计 579
