The chuck on my drill is stuck and won’t come off
Cant remove chuck tried with chuck keys and it’s solid what do I do
Open the chuck as wide as it can go and shine a light into it. There is usually a screw holding the chuck in place to stop it vibrating loose. Turn the screw CLOCKWISE to remove it as it’s a left hand thread. Then when the screw is out put a large Allen key in the chuck with the long end at a right angle to the drill and tighten it down. Lay the drill on a bench or table with the chuck over the edge and hit the Allen key with a quick blow of a hammer counter clockwise to unscrew it. Hope it helps.
这个答案有帮助吗?
hello mark
If the chuck on your Bosch Hammer Drill HD18-2 is stuck and won't come off, here are a few things you can try:
If none of these methods work, it's possible that there is a more serious issue with the drill and it may need to be serviced by a professional.
or
you can check the link for parts
这个答案有帮助吗?
过去 24 小时: 6
过去 7 天: 26
过去 30 天: 94
总计 1,386
