跳转到主内容
Released April 2022, Identified by model number XT2203-1.
3 个问题 查看全部
Bluetooth and Gps troubles after screen replacement.
Hi,
i replaced my screen and housing on my Motorola edge 30 recently and everything went smoothly. But now i have trouble with Bluetooth having bad range, it is skipping/lagging a lot and has trouble connecting. Similarly the GPS has very bad accuracy.
After looking it up it seems to be the antenna that perhaps was damaged during the repair, could this be correct?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
It seems like you already know the answer, and that sounds about right.
Just to be safe, I would probably check the connector and make sure it is fully plugged in, as this could also be causing the problems that you are having.
I believe that should fix the problem.
这个答案有帮助吗?
得分 2
2条评论:
Thank you very much! I will try resetting the connectors again just to make sure!
Do you know where the Bluetooth antenna is located on the edge 30, if i were to buy a replacement? Is it one of the surface mounted ones on the motherboard cover?
Picture of motherboard cover (this is the cover of edge 2022 but it looks the same), step 15
Motorola Edge (2022) Front Camera Replacement
完成的
I am not sure, but I bet that you can Google it to find it or look in the teardown for the device.
I don't own a Motorola so I can't look, sorry.
Glad I was able to hopefully help though!
完成的
添加一条评论
添加你的答案
Elias Forsgren 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 146
