跳转到主内容
The Infinix Hot 10i is an entry level smartphone with a 6.52 screen and a 6000 mAh battery released May, 2021.
Display does not show
Display does not show anything
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
hello Shedy willy
If the display of your Infinix Hot 10i is not showing anything, there are a few things you can try:
  1. Check if the phone is turned on: Press and hold the power button for a few seconds to see if the phone turns on. If it does, but the display is still not showing, move on to the next step.
  2. Check if the display is damaged: If your phone has been dropped or has suffered any physical damage, it's possible that the display has been damaged. In this case, you may need to replace the display.
  3. Try a hard reset: Sometimes a hard reset can fix display issues. To do this, press and hold the power button and the volume down button at the same time for a few seconds. Release the buttons when the phone vibrates and then immediately press and hold the volume up button until the Infinix logo appears.
  4. Check the battery: If the battery is low, it's possible that the display won't turn on. Charge the phone for at least 30 minutes and then try turning it on again.
If none of these steps work, you may need to take your phone to a repair shop to have it looked at by a professional.
这个答案有帮助吗?
得分 0
添加一条评论
not showw a display and sound
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
shedy willy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 759
