跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly information for Samsung's flagship S21 Ultra Android smartphone, released in January of 2021.Also known as the Samsung SM-G998U1
GPS isn't working properly etc. When driving there is no signal
Hi, my phone's GPS doesn't work when driving. Factory resetting etc doesn't work. The GPS is fine when stationary, but as soon as there is movement the GPS won't work at all. Have taken it to be assessed, and have been told a 'connector is missing'. Does anyone know what connector they are referring to and whether this can be fixed? Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hello Gerald Fernandez
It's possible that the connector the technician is referring to is the antenna connector for the GPS receiver in your phone. The antenna connector is used to connect the GPS receiver to the phone's internal antenna, which receives GPS signals from satellites.
If the antenna connector is missing or damaged, it could be causing the GPS to not work properly when in motion. This could be because the phone is not receiving a strong enough signal from the GPS satellites to provide accurate location data.
If this is the case, the connector may be replaceable, but it would require opening up the phone and accessing the internal components. It's recommended to have a qualified technician or repair shop perform this type of repair, as it can be complicated and requires specialized tools and knowledge.
这个答案有帮助吗?
得分 2
1条评论:
Thanks heaps :) I think I will go with having it repaired
完成的
添加一条评论
添加你的答案
Gerald Fernandez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 30
总计 619
