跳转到主内容
Google Pixel 系列第三代中的其中一隻。Pixel 3a為系列中主打中低價位的一員,其中,鏡頭型號與同系列旗艦款式同款。2019年五月發布,有全黑、純白、淡紫三種顏色(前兩者電源鍵為橙色,紫色為黃色)。
41 个问题 查看全部
Screen has a display but no touch screen after repair.
Hey I've got a Pixel 3a that touch screen suddenly stopped working. I suspect water damage, it was in my pocket during a pretty bad rain storm and after that the touch screen stopped working.
I replaced the screen with a non-genuine part because that's all I could find at the time, and the same issue persisted. I know it was a not genuine part because the colours are different.
My question is if there's another component on the board that could potentially be broken other than the screen? I was thinking about ordering another screen replacement (since iFixit sells genuine Google parts) but I want to see if there's anything else I can do before I pull the trigger, in case that's the issue.
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hello @kazuhiramiller, Yes can check out another screen placement, if it doesn't work that means you need to change the touch I.C
这个答案有帮助吗?
得分 2
2条评论:
How difficult is it to replace the touch I.C? Is there a tutorial I can find anywhere?
完成的
Apologies, I've just read the teardown and I see it's on the ribbon cable for the screen itself. I'll order a new screen. Thank you for much for your help!
完成的
添加一条评论
添加你的答案
Kazuhira Miller 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 145
