After replacement, battery status shows "Service Recommended"
I replaced the battery on my mid-2014 15" MacBook Pro Retina about a week ago. The battery is charging ok, and running the computer for a reasonable amount of time. However, after going through full 3 discharge - recharge "calibration" cycles, I still see "Service Recommended" on the battery status display. Is my replacement battery defective?
Update (05/02/23)
Here’s the cocoabattery info, for the new battery
https://d33v4339jhl8k0.cloudfront.net/in...
Update (05/05/23)
I added the coconutBattery report as an update to the original question. I see that the reported Full Charge Capacity of the new battery is 9925mAh, where the reported "Design Capacity" is 8700mAh.
If the higher Full Charge Capacity is causing the "Service Recommended" status, is there any way to fix this?
1条评论
由 Mark Davis 完成的
