What is the best size for the blade SSD?
Before I close everything up, just wanted to know if a 500 tb pci e card is overkill if I am also replacing the data hd with an ssd? I have a 128 gb blade I can put in its place instead. Any thoughts??
A 512GB blade SSD is what I would go with even if you install a SATA based drive be it a HDD or SSD.
The reasoning is this drive will be your boot drive hosting your OS and apps as well as be used for Virtual RAM space, Caching & depending on the apps you use scratch space.
这个答案有帮助吗?
Thanks so much!!
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 17
